Thread: AML/CEL Filter based on Variable
    23.09.2021
    8
    Default AML/CEL Filter based on Variable
    I was wondering if it is possible to filter an AML/CEL s.t the filtering is based on a Variable?
    E.G.:
    NAME_TO_SHOW="UNIT A"
    Show all alarms from Variables which contain NAME_TO_SHOW in Variable identification.
    Of course I could define separate screen switch function where possible Values of NAME_TO_SHOW are hardcoded, but that is not an option for me, as I do not know values of NAME_TO_SHOW in Advance.
    Thanks and Br,
    Lukas
  2. #
    1,059
    Default Re: AML/CEL Filter based on Variable
    So directly, from a value of some string variable to the filter, should be possible with API (AddIn Framework).
    But maybe there is a way by the use of the Equipment Model where all those valves are nodes (equipment groups). Then to call filtered based on equipment modeling (not the value of a string variable).
  3. #2
    1,059
    in the Runtime, in AML (or CEL) screen you can use button 'Filter' to configure dynamically filtering criteria, also some (sub) text in variable names or identifications:
    Or you mean another use case?
  4. #3
    23.09.2021
    8
    Thanks for the quick response!
    No I mean a different Use case. I would like to configure it within engineering studio.
    Lets say I have 100 valves. For each valve I want an popup with contains an AML/CEL with only its entries.
    Each Valve contains a variable which uniquely describes it. Lets say a String containing its name.
    Now I am looking for a solution to filter the AML/CEL based on a variable value(name of Valve).
  5. #4
    1,059
  6. #5
    03.11.2015
    41
    Yes. This is possible in the AddIn Framework.
    This is preferable to the API
  1. Substitution filter-settings variable-name in CEL
    By ptkdennis in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 30th June 2020, 10:58
  2. Rename variable based on structure datatype in editor wizard
    By bartsmets in forum Add-In Framework
    Last Post: 23rd December 2019, 13:38
  3. Filter-Variable diagnosis screen
    By jahidbagwan in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 11th March 2015, 12:21
  4. Replies: 5
    Last Post: 4th September 2013, 00:16
