Showing results 1 to 1 of 1
Thread: Code Sample creating variable in the zenon editor
    28.07.2008
    64
    Default Code Sample creating variable in the zenon editor
    In this example, a text file is opened and the contents of this are used to create variables in the zenon editor. The text file contains any desired number of lines. Each line includes the name and data type of a variable; these are separated by a comma (example: Variable1,BOOL).
    The Macro1 method first looks for the internal driver in the zenon editor. After this, the user is shown a file selection dialog in which he must select the text file. The method then reads the text file and creates the variables. The GetDataType method is then required to determine and assign the attendant data type when creating the variables.
    using System;
    using System.Windows.Forms;
    using System.IO;
    namespace WorkspaceAddin
        [System.AddIn.AddIn("MyWorkspace", Version = "1.0", Publisher = "", Description = "")]
         public partial class MyWorkspace
            private void MyWorkspace_Startup(object sender, EventArgs e)
    private void MyWorkspace_Shutdown(object sender, EventArgs e)
    public zenOn.IVarType GetDataType(zenOn.IVarType vType, string strVType)
        //gets the corresponding vartypes for bool, int, real and strings
         switch (strVType)
                 case "BOOL":
                 vType = this.ActiveDocument.VarTypes().Item("BOOL");
                 break;
                 case "INT":
                 vType = this.ActiveDocument.VarTypes().Item("INT");
                 break;
                 case "REAL":
                  vType = this.ActiveDocument.VarTypes().Item("REAL");
                 break;
                  case "STRING":
                  vType = this.ActiveDocument.VarTypes().Item("STRING");
                  break;
                  default:
                  break;
            return vType;
    public void Macro1()
           //create objects that will take the intern driver and the variable type
           zenOn.IDriver zInternDriver = null;
           zenOn.IVarType vType = null;
           //search for the Intern driver and throw exception if no driver was found
           try
                for (int nDriverCount = 0; nDriverCount < this.ActiveDocument.Drivers().Count; nDriverCount++)
                     if (this.ActiveDocument.Drivers().Item(nDriverCount).Name == "Intern")
                           zInternDriver = this.ActiveDocument.Drivers().Item(nDriverCount);
            catch (Exception xDrv)
                  MessageBox.Show("Unable to find zenon 'Intern' driver. Error: " + xDrv.Message);
                   throw;
            this.ActiveDocument.Variables().DoAutoSave(false);
             try
                  OpenFileDialog VarFileSelect = new OpenFileDialog();
                   String[] strVarLine = new String[2];
                   //show file dialog
                   if (VarFileSelect.ShowDialog() == DialogResult.OK)
                         string strLine = string.Empty;
                         //open new stream reader with selected file
                         StreamReader ImportStream = new StreamReader(VarFileSelect.FileName, System.Text.Encoding.Default);
                         //read in line by line, split the lines when a ',' occurs and create variables
                        while ((strLine = ImportStream.ReadLine()) != null)
                              strVarLine = strLine.Split(new Char[] { ',' });
                              this.ActiveDocument.Variables().CreateVar(strVarLine[0], zInternDriver, zenOn.tpKanaltypes.tpSystemVariable, GetDataType(vType,strVarLine[1]));
                ImportStream.Close();
             catch (Exception xFileRd)
                 MessageBox.Show("An error occured while opening the file: " + xFileRd.Message);
                 throw;
              this.ActiveDocument.Variables().DoAutoSave(true);
    private void InternalStartup()
          this.Startup += new System.EventHandler(MyWorkspace_Startup);
          this.Shutdown += new System.EventHandler(MyWorkspace_Shutdown);
  1. Replies: 5
  2. Word als Binär Code anzeigen
    Last Post: 26th March 2009, 19:51
  3. Information Unlimited 16 - Sample
    By robertf in forum VBA
    Last Post: 28th November 2008, 13:34
  4. rapidly creating Zenon functions using import/export
    Last Post: 10th January 2008, 10:20
  5. Replies: 0
