Thread: CSV file import error
    15.04.2021
    3
    Ausrufezeichen CSV file import error
    I'm trying to import a CSV file in utf-8 encoding(Converted to .txt form using excel) for the variables list to create variables and for some reason, Zenon throws an error that the import cannot be carried out everytime I try to import variables using my CSV file.
    But if I export the CSV from an existing Zenon project and then add my rows and columns into that CSV, the import works
    Any help would be appreciated to resolve the issue with importing the original CSV file!
    I'm using Zenon Energy edition 8.2
    VIKHASH
    1,058
    Default Re: CSV file import error
    Just the use of energy license does not make all your topics to be energy edition specific, so I'm moving this thread to the forum node where more people would be able to give some hints.
    I suppose the CSV file produced from Excel is not identical (all columns, in right order, right separators, no additional space chars, etc.) with the CSV format produced (and expected) originally by zenon.
    15.04.2021
    3
    Idee Re: CSV file import error
    Thanks for the response Ursula!
    The CSV file which zenon recognizes uses UTF-16 LE BOM encoding. But the CSV which I have is of UTF-8 encoding. That caused the issue with Zenon
    When I changed the encoding scheme to match with what Zenon accepts, all the variables were imported into Zenon from the CSV.
    VIKHASH
  1. IEC 61850 .cid file import
    By DamirO in forum zenon Energy Edition
    Last Post: 7th March 2017, 13:08
  2. Import Tagname from .csv file
    By jaroslav.kral in forum VBA
    Last Post: 1st July 2011, 13:18
  3. I always get "Error # -60 Opening file" with the function "Read Dbase file
  4. Help! I can not import my variables .dbf file
  5. Replies: 0
