Showing results 1 to 9 of 9
Thread: Create static Element Rectangle with certain properties and Position it in an existing picture
    28.07.2008
    64
    Default Create static Element Rectangle with certain properties and Position it in an existing picture
    This is just a sample how to create a static Element.
    public void Macro1()
    /* Create static Element Rectangle with certain properties and Position it in an existing picture. */
    zenOn.IDynPictures myPics = this.ActiveDocument.DynPictures();
    int iheight = 1008, iwidth = 1630;
    //Create rectangle
    myPics.Item("Background").Elements().Create("Rect_BackGrnd", zenOn.tpElementTypes.tpRectangle);
    zenOn.IElement myRectangle = myPics.Item("Background").Elements().Item("Rect_BackGrnd");
    //Position rectangle
    myRectangle.Left = 25;
    myRectangle.Top = 21;
    myRectangle.Width = iwidth;
    myRectangle.Height = iheight;
    //Change faceplate of rectangle
    myRectangle.BackColor = 16777215;
    myRectangle.set_DynProperties("PunchFrameType", 2);
    myRectangle.set_DynProperties("PunchFrameColor", 8092608);
    myRectangle.set_DynProperties("PunchFrameOffset", 0);
    myRectangle.set_DynProperties("PunchFrameSize", 10);
    myRectangle.set_DynProperties("PunchFrameAngle", 0);
    myRectangle.set_DynProperties("PunchFrameAlpha", 66);
    myRectangle.set_DynProperties("PunchFrameSoftFocus", 20);
    16.06.2011
    N/A
    43
    Default Re: Create static Element Rectangle with certain properties and Position it in an existing picture
    I have error :
    Error 1 'ProjectAddin.ThisProject' does not contain a definition for 'ActiveDocument' and no extension method 'ActiveDocument' accepting a first argument of type 'ProjectAddin.ThisProject' could be found (are you missing a using directive or an assembly reference?) C:\ProgramData\COPA-DATA\SQL\0a8f95d5-b6e6-42d3-858e-f12b1741048f\FILES\zenon\system\VSTA\CSharp\Projec tAddin\ThisProject.cs 25 46 ProjectAddin
    in line:
    The "ProjectAddin" you are using, is the VSTA workspace for the runtime.
    If you want to add a rectangle element to the screen in the editor, you need to use the "WorkspaceAddin" instead.
    The VSTA IDE for the ProjectAddin and the WorkspaceAddin is opened in different ways.
    For the ProjectAddin, you select the tree node "programming interfaces" and here you can choose to open the VSTA IDE for the workspace for anything in the runtime.
    For the WorkspaceAddin, you can either press "Alt+F10" or choose to open the VSTA IDE from the "File menu" or by right clicking on the workspace itself. In the WorkspaceAddin workspace is used for anything in the editor (e.g. creating a screen, and adding a rectangle)
    16.06.2011
    N/A
    43
    Can I create Rectangle in Runtime? Do I have to use the "ProjectAddin"?
    881
    Default AW: Create static Element Rectangle with certain properties and Position it in an existing picture
    FYI: drawing elements via the zenon API interface is no longer possible with the upcomming version zenon 7 (this feature was removed).
    Maybe you can give us a more detailed description what exactly you want to realize.....
    Did you know that you can make rectangles created in the editor, change in size, move position, invisible and visible and start and stop flashing in the runtime, using variables?
    Herbert is right, could you please give some more information as to why you would want to create a rectangle in the runtime dynamically?
    21.05.2014
    32
    I have a similar target to achieve. I create a numerous elements in Zenon explicitly to access them in VBA or VSTA would be touch sometimes (depends on the number of variables). I have an application in VB, that generates boxes in runtime using just one label in the form and loading it repeatedly with particular specified dimentions. I am looking forward to create such method in VBA or VSTA to realize in Zenon. This makes it even effective for visualization purpose and further advancements.
    Bytheway, I am using Zenon 6.51
    Jyothi swaroop
    20.01.2015
    18
    Hey!
    Is this macro always working ?
    I write this macro in "WorkspaceAddin", but this is doesn't work!
    Where do i to call the macro ? MyWorkspace_OnWorkspaceStartup() ? MyWorkspace_OnPreVSTAUpdate() ? MyWorkspace_OnPostVSTAUpdate() ?
    Varnizy Loan!
    please have a look in the documentation,
    Manual -> Programming interfaces -> VSTA
    Escpecially here on how to execute the Macro:
    Manual -> Programming interfaces -> VSTA -> Creating a VSTA project -> VSTA projects in the editor
    If you are planning to do more with VSTA I would highly recommend visiting a zenon API training.
    Kind regards,
  1. Create a function for a trend picture
    By robertf in forum VBA
    Last Post: 4th October 2018, 14:33
  2. Create an Element
  3. Replies: 6
    Last Post: 1st December 2009, 12:56
  4. can't create new project in zenon editor
    By shahramkh59 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
  5. How to create a new MACRO?
    By matholton in forum VBA
