Thread: Standard Recipes grey window
    21.01.2020
    8
    Default Standard Recipes grey window
    Hey!
    I'm working with 64 bit ZEE 8.20 build 67700 and I encountered a problem. I was working with Standard Recipes window and it worked fine when I had only one recipe defined. When I defined a few other recipes, I couldn't access any other recipes anymore, the window is just grey. I can create more recipes eg. "Recipe 5", "Recipe 6" etc, but can only access the last one. After deleting it, the Standard Recipes window is grey again and I can't do anything besides adding another recipe. I tried using "Jump back to starting element" button, but to no effect.
    After exporting as XML, the recipes in the file are fine.
    Below is a screenshot of how it looks like when I create a new recipe:
    And after I delete it:
    1,107
    Default Re: Standard Recipes grey window
    as this is nothing specific to the energy, but general knowledge about zenon, i'm moving your post the forum node where the are more people reading, so better chance to get an fast answer.
    my solution proposal - try to correct your view:
  1. Converting Standard Recipes to use with a Recipe Group Manager
    By roger_novarctech in forum Add-In Framework
    Last Post: 31st October 2019, 18:42
  2. Filter the list of Recipes
    Last Post: 19th September 2019, 23:52
  3. Replies: 1
    Last Post: 11th September 2019, 21:54
  4. recipes password
    By aleb2 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 19th December 2016, 15:16
  5. copy recipes
    By hicom in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 11th May 2009, 05:28
