Thread: HTML 5 Web engine for internet accessibility
    27.08.2021
    Default HTML 5 Web engine for internet accessibility
    Hello everyone,
    I have a project with web engine implemented , so the user can access the SCADA System using his mobile phone as long as the user is still connected to the network.
    at the moment I am willing to host the web engine application on the internet so it can be accessible from even outside the local network.
    My question is as follows:
    what is best recommended by CopaData to provide a secure connection to the server where the SCADA system is running? knowing that connecting the server to the internet by setting up a public IP isn't safe.
    Thank you in advance .
    best regards.
    Charbel Saikaly.
    67
    Default Re: HTML 5 Web engine for internet accessibility
    Quote Originally Posted by CharbelSaikaly View Post
    Hello everyone,
    Hello CharbelSaikaly,
    An official statemant concerning web can be found here:
    https://www.copadata.com/de/support-...erations-2052/
    To give additional info, I would suggest the following: It's probably best and the easiest to use an internal VPN to connect to the company network instead of exposing the web engine directly to the internet.
    If that's not possible, I would make sure:
    • to use the network encryption with a strong password - the same should be applied for the users which are allowed to use the webengine (strong passwords).
    • The server which is hosting the Service Engine Connector should be configured as a Service Engine Client and not be a vital networking part (standby, collection of plc-data etc.)
    • Other than that, the HTML-Engine Website is SSL-Secured and traffic between server and client is encrypted.
    • Make sure to use a valid and officially signed certificate for your IIS deployment.
    I hope this info helped.
    BR,
    Joris
  1. Webserver in internet environment
    By joelprasad in forum Smart Server & Smart Client (former Webserver & Webclient)
    Last Post: 31st October 2017, 18:28
  2. Web Client - Visible Scrollbar on Internet Explorer in full screen mode
    By steven.costantini in forum Smart Server & Smart Client (former Webserver & Webclient Setup)
    Last Post: 15th February 2017, 09:22
  3. Web server client, blue dots when connected via internet
    By JamesPressure in forum zenon Network
    Last Post: 31st May 2016, 07:59
  4. Internet-Explorer ActiveX Objekt
    By rabi in forum zenon Network
    Last Post: 20th March 2015, 10:06
  5. Internet Explorer 8.0 for Web-Client ?
    By lephis in forum Smart Server & Smart Client (former Webserver & Webclient)
    Last Post: 3rd June 2011, 06:34
