Page 1 of 2 1 2 LastLast
Showing results 1 to 10 of 13
Thread: Draw line dynamically?
    01.02.2016
    57
    Default Draw line dynamically?
    Hi all.
    1. How to dynamically draw polyline on scada screen?
    We have 10 measuring points, which should be connected with lines. About every 5 minutes, scada get meas. value.
    2. Extended trend - how to clear trend on variable change. So, when variable value False, trend empty. When it goes to True, starts to drawing trend ...
    BR,
    Miloš
  2. #
    1,059
    Default Re: Draw line dynamically?
    This is how the inspiration by your use case looks then in the runtime in sample project :
    And the zenon Logic code delivering the coordinates of limit lines (green areas):
    But i'm not happy how the trend XY threats the last received limit value when after pre-draw of limits then only data about the measurement (the black curve) comes. The solution with pre-draw of limits works only when limit by 100% is the lowest any by display type "area" (not line),; so, it will not have nice display if the last limit would be bigger as those for lower %. And to setup this trend demands advanced knowledge in zenon, Historian and zenon Logic.
  3. #2
    01.02.2016
    57
    Hi again,
    I realy need help here.
    I would like to display simple XY line graph . All axis should be fixed interval.
    X axis 0...100% - flow
    Y axis -3...3 - error
    Example:
    Every xx seconds system generates one point (X,Y) from 100% to 0%
    after 10sec 97% - 0,12
    after 10sec 65% - 0,11
    after 10sec 46% - 0,08
    etc.
    How to make this graph?
    It should be like an image attached...
  4. #3
    1,059
    From which zenon driver you have variables with value X and Y? Do the values on X and Y variables have exactly the same time stamp?
    I propose you not to try draw the lines (draw is in Editor, in the Runtime - size and position dynamically), but to use Extended Trend - it is a dedicated screen type.
  5. #4
    01.02.2016
    57
    Thanks for reply,
    It's internal variables calculated in zLogic.
    I tried with XY display...but there also some other questions...
    For every point we have X,Y pair (xvalue,yvalue).
    So after xx seconds we should to connect next points (like series).
    We need to draw limit lines before measuring starts, and after that system generates points from internal values like
    X1-ValueX[0], Y1-ValueY[0]
    X2-ValueX[1], Y2-ValueY[1]
    One option is to use WPF with windows chart control?
  6. #5
    1,059
    Why not the Extended Trend?
    I'm still not understanding your use case, so it will be hard to give the best solution proposal.
  7. #6
    1,059
    If in Extended Trend: it will not draw XY for arrays variables. But it will draw for single variables when their value series are stored in Historian or HDD (variable properties - Harddisk data storage).
    Or if you configure Logic to deliver the array as a Block Array (variable properties - Additional settings - Block array size), so via register of 10(?) offsets in Logic MODBUS slave (to zenon MODRTU driver - single variable configured to be 10 items block array).
    To give you better description of Extended Trend solution I have to first well understand the use case.
    If not Extended Trend then you can (but this will be quite much work): draw in Editor a set of flat lines with the chained horizontal points and in the runtime then return from logic calculated there dynamical (so on additional variables) for each line: line size, position and rotation. See line properties - position - X/Y position dynamically; and size and rotation dynamically.
    If you like you can program a WPF.
  8. #7
    01.02.2016
    57
    Hi, thank's again for your efforts to solve this.
    See attach. That's how it should looks like.
    Red lines should be "printed" on graph before measuring starts.
    Then when measuring starts it always goes from greater flow (black line).
    So we have pairs (example):
    point 1 - (flow,error) - (100%, 0,12%)
    point2 - (65%, -0,08%)
    etc.
    Note: Grey line is not needed.
    I tried with ET, but I'm not sure how to get final results?
    I used new internal values IFLOW and IERR. Then in zLogic everytime I get measuring point from array
    i do this:
    IFLOW = ValueX[0]
    IERR = ValueY[0]
    This two variables are used in XY ET display...
  9. #8
    01.02.2016
    57
    Quote Originally Posted by JakaBasej View Post
    Have you tried vector programing like R?
    Sorry, I didn't understand question?
  10. #9
    1,059
    have the red lines fix position or dynamical? if dynamical - what (variables?) impact it?
  11. #10
    01.02.2016
    57
    Hi Ursula...
    Red lines have 3 fixed posibilities.
    If variable ErrorLimit = 2, then it looks like on image... (on 20% X axis, error limit (red line) goes from 2 to 1 - upper limit, and from -2 to -1 lower limit).
    If Error limit = 1 then (on 10% X axis, error limit (red line) goes from 2 to 1 - upper limit, and from -2 to -1 lower limit)
    If Error limit = 1.5 then (on 15% X axis, error limit (red line) goes from 2 to 1 - upper limit, and from -2 to -1 lower limit)
    So the red line in sense of Y axis is always the same.
    ET starter edition does not support XY display?
  1. How to define register address dynamically?
    By kuki in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 16th November 2015, 12:01
  2. dynamically create Alarm Areas
    By mkerle in forum VSTA
    Last Post: 24th November 2011, 09:47
  3. How to draw mimics in zenon Editor
    By nahala in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 27th April 2009, 08:31
  4. Trend Line
    By rloureiro in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 16th December 2008, 10:52
  5. Dynamically changing alarm descriptions
    By mattsd in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 9th November 2007, 10:44
