Is it possible to display a trend on windows ce devices
There are two possibilities
You can use the dynamic element trend for displaying data. This element requires, that the variables which should be displayed must write the data on the hard disk. The update time of the element and the scan rate of the HD variable should be set up equally.
The second possibility is an Active X control which displays values from the archive driver.
