Thread: AML time received/cleared equal from logic
    26.02.2021
    30
    Default AML time received/cleared equal from logic
    I'm having a problem with the timestamp of bools coming from logic.
    I just programmed a DINT split into Booleans through Zenon Logic. Everything is working fine EXCEPT that the timestamp in the AML is wrong. All the alarms configured through Logic have the same time for received and cleared, and both of those times are incorrect.
    Any idea why that can be happening?
    **I programmed it by copying the data into an array of bolleans by:
    My_Bool_Of_Array[0]:=My_Dint_Variable.0;
    My_Bool_Of_Array[1]:=My_Dint_Variable.1;
    My_Bool_Of_Array[31]:=My_Dint_Variable.31;
    Is there a better way to do it?
    26.02.2021
    30
    Default Re: AML time received/cleared equal from logic
    Never mind...
    I realized that I had those variables set us Internel driver (with external visibilty configuration) so the splitting of the DINT variable was getting done, but the timestamp wasn't processed properly.
    I already changed them to StratonNG and everything is working perfectly...
  1. Firewall prevented packet sent from PROFINET device to be received by PROFINET controller in zenon Logic
    By ChristopherK in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 22nd June 2020, 10:06
  2. Number of cleared Alarms in the AML with Ring buffer
    By freddieamuna in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 29th January 2019, 18:32
  3. How to use Zenon Logic with RTU & also with SCADA at the same time.
    By rajsiyer in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 27th February 2015, 12:48
  4. how to show cleared value in alarm, etc.
    By mnette81 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 5th December 2013, 10:09
  5. Read Date & Time from Time Attribute on IEC61850
    By salmanhassan2 in forum Drivers
    Last Post: 22nd February 2013, 07:34
