Thread: Min and max set value from another varibale?
    01.02.2016
    55
    Default Min and max set value from another varibale?
    Hi all.
    I made two buttons, 1st button INC, increments variable value named INDEX by 1. Also there is DEC button which decrements INDEX by -1.
    I would like to dynamicaly change max set value limit for Index variable.
    Sample.
    Max set value should be limited by value from variable MAX_INDEX.
    When user click on button INC the value Index increments untill it reached MAX_INDEX value.
    How to achieve this?
    BR,Miloš
    1,038
    Default Re: Min and max set value from another varibale?
    you will need zenon Logic. or API.
    273
    Default AW: Min and max set value from another varibale?
    ...or you create a boolean Math-Variable with Formula: INDEX >= MAX_INDEX and use this Math-Variable for the visibility of the INC Button (Visible from 0 to 0)
    (same for the DEC Button with MIN_INDEX)
    ...or use an Interlocking to lock the INC/DEC Buttons
  1. Reg: DPC Testing with varibale daignosis
    By saravanan1985 in forum zenon Energy Edition
    Last Post: 24th May 2018, 14:40
