Thread: Can't run "subproject VBA function" from integration project.
    04.04.2011
    9
    Default Can't run "subproject VBA function" from integration project.
    Hello.
    I have integration project with 6 subprojects. One of the task is to running some subproject VBA functions from integration project main screen.
    For example, I use the code like this:
    Code:
    ApplicationED.Projects.Item("SUBPROJECT_NAME").RtFunctions.Item("SUBPROJECT_FUNCTION_NAME").Start
    But nothing changes.
    This code, for changing variable, works fine:
    Code:
    Projects.Item("SUBPROJECT_NAME").Variables.Item("SUBPROJECT_VARIABLE_NAME").Value = 1
    Where is my fail? Should I change some project settings for correct work?
    10.12.2007
    271
    Default AW: Can't run "subproject VBA function" from integration project.
    You've got it already in your example: simply don't use "ApplicationED" because this is the Editor Application, not the runtime. I usually go via thisProject.Parent.Projects.Item("...")...
    04.04.2011
    9
    Default Re: AW: Can't run "subproject VBA function" from integration project.
    Quote Originally Posted by mst View Post
    Thanks for the answer. I changed code but nothing new.
    Code:
    thisProject.Parent.Projects.Item("SUBPROJECT_NAME").RtFunctions.Item("SUBPROJECT_FUNCTION_NAME").Start
    MsgBox "OK"
    Message box didn't shows too. I think there is some error in code, but I understand where. The code is so simple.
    04.04.2011
    9
    Default Re: Can't run "subproject VBA function" from integration project.
    All works ok. The problem was in another place.
  1. "Variable Use" list in "Project Analysis" window shown Empty
    By swamy.panakala@gmail.com in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 30th November 2019, 08:02
  2. Do not reload AddIn - With function "Reload project online"
    By tsvoboda in forum Add-In Framework
    Last Post: 1st October 2019, 11:00
  3. Replies: 0
    Last Post: 25th February 2019, 09:19
  4. Change the Variable linked to a "Numeric Value" or to a "Dynamic Text" in the Runtime.
    By hamiiiz in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 13th March 2017, 13:51
  5. I always get "Error # -60 Opening file" with the function "Read Dbase file
