Thread: Modifying bit in Word
    10.06.2021
    2
    Default Modifying bit in Word
    Hello!
    Sorry for my bad English, but I hope you will get me!
    Can I write/modify a bit in a whole Word variable with a Button, Combined Element or anything else?
    As you know, a Word variable got 16 bit (so every bit can be 0 or 1). So I would like to modify the first 4 bits by 4 buttons (button 1 is linked with bit 0, button 2 is linked with bit 1 …etc.). Every button must modify just one bit and not the others.
    To be more specific in what I need. For example, the button 2 is ON and the others are OFF (then the value of the word is 2). If I turn on the button 3, the value of the Word should get 6 (bit1=2, bit2=4, 2+4=6). Then If I turn off the button 2, the value should get 4 and not 0.
    May can I use such like a script or a programming thing to do that?
    Best regards.
    1,059
    Default Re: Modifying bit in Word
    Not directly in zenon screen elements. You can split this word variable to 16 stratonNG variables. The zenon Logic can as well get as put word <-> bits.
    10.06.2021
    2
    Thanks’ for the reply
    I found another way to do that. In the programming interface, I made a macro (VBA) for what I need and it's working perfectly!
    However, I have another question now. Can or how can I add a macro in Smart-Objects?
  1. Key word
    By stefaninotl in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 13th July 2017, 12:52
  2. Reading bit from word
    By kuki in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 31st May 2015, 14:20
  3. Can zenon handle 800,000-word-tags?
    By sunnamkung in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 26th March 2012, 23:22
  4. Replies: 1
    Last Post: 31st January 2011, 15:23
  5. Word als Binär Code anzeigen
    By sknoerr in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 26th March 2009, 19:51
