Thread: Write calculated variable to the PLC
    10.05.2021
    16
    Default Write calculated variable to the PLC
    Hello, I am wondering about limitation of managing variables. Simple task is to write calculated variable to the PLC. For example I want to make sum of two variables and write result to PLC variable. Any suggestions?
    Best regards
    1,023
    Default Re: Write calculated variable to the PLC
    use zenon Logic.
    on the forum there are many posts with "how to" hints.
  1. Write variable from background worker
    By debaru in forum VSTA
    Last Post: 5th July 2021, 14:05
  2. Write values to variable is too slow
    By SmartS in forum zenon Service Engine Supervisor
    Last Post: 15th June 2021, 14:52
  3. To Create Realtime Values Calculated in Certain Period of Time
    By Zeynel in forum zenon Energy Edition
    Last Post: 4th March 2020, 15:41
  4. To Write Value in Variable with Status
    By rahulindore05 in forum VBA
    Last Post: 3rd June 2019, 10:03
  5. Replies: 2
    Last Post: 22nd September 2011, 01:32
