Thread: network configuration
    07.07.2021
    Beitrag network configuration
    HI  COPA-DATA team
    I have question's about Zenon network connection,  for example, if we have two pc in the same network based on DCOM, we installed in pc one OPC server (we use codesys OPC and name pc1) then in another pc (pc 2) we have Zenon, now my first question is
    is that possible to access data (read/write) from Zenon in pc2 to pc1 in this network?
    so if possible how can we configure it?
    best regards .
    1,025
    Default Re: network configuration
    Consider to NOT use (OPC DA via) DCOM, this is a technology unsuitable for reliable production processes, e.g.: it is very probable that after any connection breaks you will have to hard restart components, else they will not communicate.
    I propose you to use on both PCs the zenon Network, so to run zenon runtime also on the PC with OPC server (COM, not DCOM). The subproject dedicated for pc1 can contain the zenon OPC client driver. The zenon Network will exchange data between PCs. The zenon on pc2 will be client of project on pc1 (while pc1 will be client of your current project on pc2).
  1. Network Authorization for Users
    By josejoyrl in forum zenon Energy Edition
    Last Post: 30th July 2019, 09:41
  2. Network issue
    By vyshvija in forum zenon Network
    Last Post: 16th April 2019, 08:57
  3. Network Topology
    By horstd in forum VSTA
    Last Post: 29th March 2019, 09:40
  4. Network Status
    By sidramsatyal in forum zenon Network
    Last Post: 16th December 2013, 12:56
  5. Network Project
    By fafdaniel in forum zenon Network
    Last Post: 5th October 2011, 23:33
