Thread: AML/CEL Message with exception
    01.03.2018
    8
    Default AML/CEL Message with exception
    a customer gets this message when he hits the button Filter... in the screentype alarmlist:
    Exception in Wnd=0x028A01F0(ALARMLISTE) processing message 0x0111
    IParam=0x00000000 wParam=0x00002721
    Someone here with experience with this problem? Is it the same problem as in Thread: AML/CEL filtering issue https://forum.copadata.com/showthread.php?9524-AML-CEL-filtering-issue?
    Version V7.00
    272
    Default AW: AML/CEL Message with exception
    Yes I think this is the same reason. Build 32 (10885) will fix this problem in v7.0.
    01.03.2018
    8
    Default Re: AML/CEL Message with exception
    Thanks a lot!
  1. Message in unhandle exception
    By mytom in forum zenon Energy Edition
    Last Post: 2nd May 2018, 12:07
  2. Zenon 64 Bit application is not opening - unhandled exception- exception code C0000005 ACCESS VIOLATION
    By Dhanapal in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 23rd January 2018, 16:12
  3. COM Exception
    By schirgitom in forum VSTA
    Last Post: 10th April 2016, 17:40
  4. Replies: 0
    Last Post: 27th September 2007, 13:17
