Thread: basic mathematics in report generator
    affoltep Gast
    Default basic mathematics in report generator
    Hello
    I wonder about the syntax and possibilities in report generator.
    If I get for example two values by "=variabler(....)" in cell A1 and A2.
    In A3 I can add them without any error with the command "=A1+A2".
    But I can not sub them with "=A1-A2", I always get an error "#BADOP!)
    What is the meaning of all the "#...." messages. I couldn't find anything in the help
    What is the correct syntax for variables for basic mathematical functions as "+", "-", "*" and "/". I couldn't find anything in help neither.
    Default Re: basic mathematics in report generator
    pleae try using parenthesis:
    =(A1-A2)
    this should work.
    Did you get this error also in the Runtime?
    Diference between add and sub:
    The report can add numbers and characters but only sub numbers.
    Ok lets play a little bit:
    start with numbers
    cell value/function
    A1 5
    B1 2
    C1 =A1+B1
    D1 =A1-B1
    editor C1 -> 7; D1 -> 3
    runtime C1 -> 7; D1 -> 3
    Cells with numbers are workung with add and sub
    Same with strings
    cell value/function
    A1 abc
    B1 def
    C1 =A1+B1
    D1 =A1-B1
    editor C1 -> abcdef; D1 -> #BADOP!
    runtime C1 -> abcdef; D1 -> #BADOP!
    Cells with strings, only add is working
    Same with functions
    aktual value of variable variblename1=5
    aktual value of variable variblename2=2
    cell value/function
    A1 =variabler("variblename1","value") displayed as - (minus)
    B1 =variabler("variblename2","value") displayed as - (minus)
    C1 =A1+B1
    D1 =A1-B1
    editor C1 -> --; D1 -> #BADOP!
    runtime C1 -> 7; D1 -> 2
    Editor: the report interprets the functions as strings.
    Runtime: the report replace the function with values.
    affoltep Gast
    Default AW: basic mathematics in report generator
    Yes, it is just in editor - I always thought #BADOP! means that it doesn't work in rt, too.
    Thanks for your help.
  1. MATHDR32 mathematics drive is too weak?
    By lephis in forum Drivers
    Last Post: 27th May 2010, 13:33
  2. Handling Asynchronous Data - Report Generator
    By mike.edkins in forum Drivers
    Last Post: 3rd February 2010, 13:35
  3. Report Generator
    By rolindo in forum zenon Supervisor
    Last Post: 21st November 2009, 23:50
  4. Report Help
    Last Post: 26th November 2008, 09:08
  5. values of my mathematics driver suddenly missing
    Last Post: 20th August 2007, 12:10
