Thread: Variable identification for SO varaible
    01.02.2016
    55
    Default Variable identification for SO varaible
    Hi all.
    I made SO variable called SO_NAME (internal-bool), with empty field Variable identification.
    Then made screen symbol with dynamic text field, which use SO_NAME as Varibale identification as text.
    Also, I made project variable INT_NAME (internal-bool) where Variable identification defined as : MOTOR1.
    Then I do mapping SO_NAME <-> INT_NAME
    Put SO symbol to project screen.
    But dynamic text filed was not populated with text. MOTOR 1, it stays empty...
    BR,
    MK
    05.11.2019
    Default Re: Variable identification for SO varaible
    I have experienced the same thing. Solved this by releasing the identification property, and typing it into the "released" properties at each instance of the smart object.
    BR
    -TAK
    01.02.2016
    55
    Quote Originally Posted by ex_thkit View Post
    BR
    -TAK
    Yes, that's the only solution now...
    23.09.2021
    8
    Quote Originally Posted by milosh View Post
    Hi all.
    BR,
    MK
    It seems as if you tick the "use variable properties of Smart Object" during mapping of your SO_NAME < - > INT_NAME.
    I think it should work if you untick this option.
    But be aware. NONE of the variables properties of the SOT variable will be used.
  1. Acces variable identification/tagname straton
    By redjon in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 27th November 2017, 09:21
  2. Variable Identification in REMA
    By diemon in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 13th January 2015, 11:14
  3. Replies: 7
    Last Post: 15th January 2014, 10:48
  4. Trending display with variable identification
    By yitlilee in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 19th December 2013, 15:27
  5. variable Identification
    By paruvathakumar in forum VBA
    Last Post: 13th September 2012, 00:31
