Showing results 1 to 1 of 1
Thread: The value of the Zenon variable is not changed from C # code.
    09.04.2015
    17
    Default The value of the Zenon variable is not changed from C # code.
    I'm trying to set the value of the Zenon variable in C # code in the following way:
    Code:
    zVariable.SetValue(newValue, Constants.STATE_SPONT, (int)InternalHelpers.TimeConversion.SystemToZenOn(dt), 0);
    Code:
    _utils.AddLine($"Variable: {zVariable.Name} Wert: {newValue} Datum: {dt} in der Funktion {MethodName} geschrieben");
    The Zenon variable name is formed like this:
    https://forum.copadata.com/showthrea...ured-data-type
    In the Zenon project, the variable is in a Real format, in C # in a Double.
    Everything is displayed correctly in the log file, but the new value is not assigned into the Zenon variable .
    Which Zenon settings should I pay attention to?
    Thank you in advance.
  1. Zenon editor 8.2 install fails, due to SQL Server Rules Check code (-1)
    By cannonpm in forum Engineering Studio & Service Engine
    Last Post: 2nd March 2021, 03:23
  2. How to change? VBA code -> c# code
    By backjahyun in forum VSTA
    Last Post: 22nd March 2016, 07:46
  3. Using C++ code in Zenon
    By mrocznia in forum VSTA
    Last Post: 22nd January 2014, 14:42
  4. How to trigger a function when a variable changed?
    By denver in forum zenon Service Engine Supervisor
    Last Post: 16th May 2012, 10:12
  5. Replies: 0
    Last Post: 11th March 2010, 15:59
