Thread: Recipe change logging
    06.09.2019
    9
    Default Recipe change logging in Runtime
    Is it possible to log recipe changes in Runtime with date and time, the recipe changed, which parameter was changed and who changed it?
    I've heard that the CEL could be used for this but don't have the details. How would one use the CEL for this?
    zenon Supervisor 8.20 build 82266 64-bit
    Default Re: Recipe change logging
    hi,
    please check by doing changes as below
    06.09.2019
    9
    Thanks! After some trial and error we got it working.
    The text that appears in the CEL doesn't appear to be based on the text in the fields marked in the attached image. It's unclear where that text is used in Runtime.
    In order to change the text that appears in the CEL we used a language file where text that does appear in a recipe change CEL entry can be replaced.
Name:	recipe logging 2021-06-08 08_46_40-Clipboard.png
  1. Variable value change logging in CEL combined with other values
    By anemet in forum zenon Service Engine Supervisor
    Last Post: 9th March 2020, 14:11
  2. Replies: 2
    Last Post: 27th November 2019, 10:30
  3. Logging in the AddIn Framework
    By roger_novarctech in forum Add-In Framework
    Last Post: 23rd September 2019, 07:56
  4. RGM - VBA - ".Save" / ".Read" - change recipe status
    By markclemens in forum zenon Service Engine Supervisor
    Last Post: 29th September 2014, 12:25
  5. Logging into multiple projects
    By jurijcadez in forum VBA
    Last Post: 27th November 2012, 15:52
