Thread: Remanent fucntion
    26.02.2021
    24
    Frage Remanent fucntion
    Hi everyone,
    Is there a way to make functions remanent?
    I have a project where I have a setup screen. On this setup screen I have a few "Main/project" functions that won't be accesible for the final client, just for the manifacturer of the machine.
    This machine can be installed anywhere in the world. Among others, the functions I have in that setup screen are Languages changes, and units changes. When installing the machine we want that the "start up" technician set this functions up at runtime and no one in the factory will change that. The problem is that  if the runtime is stopped and start again, the values of this functions go back to the initial which would be "english" and "metric", Could I somehow make the functions remanent to ensure any Stop/start of the runtime won't affect this set up?
    Thank you so much.
    18.12.2017
    37
    Default Re: Remanent fucntion
    Hi!
    You could use some remanent internal variables to trigger the functions in a REMA. Then they would run after a restart.
    For example an UINT where 1 would trigger "English", 2 for "Spanish" and so on.
    26.02.2021
    24
    Good suggestion, its working fine!!
    Thank you so much.
  1. Remanent variable on Web client
    By ivavid in forum zenon Service Engine Supervisor
    Last Post: 12th April 2021, 07:54
  2. Zenon internal variable ( remanent) value
    By VenkataramanH in forum zenon Service Engine Supervisor
    Last Post: 27th March 2021, 13:14
  3. Remanent variables
    By dcs.engineer in forum zenon Service Engine Operator
    Last Post: 28th June 2017, 09:01
  4. "variable image remanent" setting is not saved
