Thread: UTC time conversion
    29.10.2018
    Default UTC time conversion
    HI,
    I have this problem:
    By a graphical interface, an operator enters a time of day at which he wants to turn on a device (Ex. 18:20)
    Using the zenon logic DTCURTIME function I get a DINT with the current time in UTC converted to ms.
    The operator is in Italy so when the pc marks 18:20, the function returns 16:20.
    How can I convert the time entered by the operator into UTC (from 18:20 to 16:20) or vice versa convert the current UTC time into Italian local time?
    22.04.2021
    5
    Rotes Gesicht Re: UTC time conversion
    I have the same problem, did you solve this issue ?
    Thank you in advance.
    18.02.2015
    2
    Default Re: UTC time conversion
    You must to use the FB DTCURDATETIME, thee is a Boolean input, bLocal, to select the GMT(FALSE) o Local time(TRUE).
    BR,
    22.04.2021
    5
    Quote Originally Posted by eugenio View Post
    BR,
    it's working, thank you
  1. zenon 3.52 conversion to 6.51
    By aHmp in forum zenon Service Engine Supervisor
    Last Post: 19th June 2020, 13:10
  2. Conversion from v7.0 to v7.2 problem
    By djosic in forum zenon Service Engine Supervisor
    Last Post: 5th August 2016, 14:04
  3. Metric / English Unit Conversion HMI
    By jkoehler in forum zenon Service Engine Supervisor
    Last Post: 14th July 2011, 16:52
  4. Conversion from 6.22 to 6.50
    Last Post: 4th April 2010, 07:58
  5. Project conversion 6.20 -->6.22
    By ionvalesareanu in forum zenon Service Engine Supervisor
    Last Post: 23rd June 2009, 08:04
