Thread: Automatic line coloring and MMXU
    05.12.2019
    Default Automatic line coloring and MMXU
    I am new to zenon and I ave tried to connect automatic line coloring with MMXU1 lock of measuring voltage. So, when you have voltage over some value the line should be colored otherwise it could be white. But can not connect MMXU1 block with automatic line coloring. If I set MMXU1 as variable and add formula (X01.Value >= 100) inside combine element representation for source, like it is done in zenon energy edition tutorial on zenon website, for value 101 I got colored lines bur for 102 not (example also not colored for 123, it is colored only for those numbers which representation get 1 on the begining)
    Why?
    Kind regards.
    983
    Default Re: Automatic line coloring and MMXU
    ALC colors the relevant lines according which switches/disconnectors/sources etc. are closed or open (variable values: 0-off, 1-on, 2- intermediate, 3 - error); not because of some measured values of (float) variables with voltage or power or whatever.
    Thus, to color the lines you have to link the Pos/stVal[ST] variables (e.g. position of a controllable circuit breaker *CSWI/Pos/stVal[ST]); and not some [MX] analog value measurement from MMXU.
  1. ALC Alarm Line Coloring
    By Gilmar in forum zenon Energy Edition
    Last Post: 1st April 2021, 11:56
  2. Automatic line coloring issue
    By konsistek in forum zenon Energy Edition
    Last Post: 10th December 2019, 14:04
  3. Coloring like lines
    By zeynal.sabas in forum zenon Energy Edition
    Last Post: 26th April 2018, 11:59
  4. Automatic Line Coloring
    By yolovs in forum zenon Service Engine Supervisor
    Last Post: 12th July 2013, 13:50
  5. Automatic line coloring (ALC) and DPI variables
    Last Post: 22nd July 2009, 14:12
