Thread: Memoryleaks
    28.10.2020
    10
    Default Memoryleaks
    Hello!
    We are running several Addins in our Runtimes and we are always experiencing a slow rising RAM usage from the runtime when have addins active. Anyone else experienced that issue aswell?
    When analyzing the Memory, it showed us only ~10MB used by our addins while the RT was at around 500-1GB of RAM (99% of it "unmanaged Memory").
    More in-depth analysis showed, that the Runtime is generating TONS of finalizable objects. The highest logged was at around 5 Million objects, sadly we could only investigate several snapshots which had around 1000-8000 queued finalizable objects which had the type: "InteropSponsor" and "VariableAdapter". Both from the ScadaAddin Library.
    I guess this could cause the memory leak? Why are this objects created and why are there millions of them generated over several hours?
    Could it be caused by looping through all available RT variables?
    Thanks in advance!
    Best Regards and stay safe!
    Markus
    222
    Default Re: Memoryleaks
    Hi Markus,
    what are you doing in your AddIn?
    Can you share the code? At least the sections that access the zenonAPI?
    Maybe you are creating objects and never deleting them?
    Quote Originally Posted by VCmarkus View Post
    Hello!
    Thanks in advance!
    Markus
    28.10.2020
    10
    Hello Felix,
    The Addins we are using are a bit too big for posting in here, but basically this is the only way i am accessing te zenonAPI. Maybe calling the API like this multiple times per minute causes leaks somehow?
    public static T LoadVariable(IProject project, string name, ref ErrorLog errorLog)
    string value = "";
    try
    if (project.VariableCollection[name].IsOnline)
    value = project.VariableCollection[name].GetValue(0).ToString();
    else
    errorLog.Add(name + "Offline");
    if (value == "")
    errorLog.Add(name + "(Empty)");
    catch (Exception ex)
    errorLog.Add("Failed to read value: " + name);
    if (typeof(T) == typeof(bool))
    return (T)Convert.ChangeType(int.Parse(value == "" ? "0" : value), typeof(T));
    else
    return (T)Convert.ChangeType(value, typeof(T));
    Quote Originally Posted by felixst View Post
    Hi Markus,
    222
    Hi VCmarkus,
    in this snippet I don't see anything that should cause rising memory consumption.
    What zenon version and build number are you using?
    I suggest to contact your local COPA-DATA support in order to discuss deeper analysis options.
    28.10.2020
    10
    Hey!
    I think we were running Zenon 8.20 65486 at that time. I will send a ticket.
    Are there any special calls which can cause a leak at the moment? So i can crosscheck those options with the code?
    Markus
    Hi VCmarkus,
