Thread: Get IEC870 driver state
    10.12.2015
    2
    Default Get IEC870 driver state
    Dear CopaData developers!
    I ask your help in the following problem:
    I have a system where the primary server communicates with PLCs via IEC60870-5-104 (IEC870) communication protocol. With the "Driver commands" function group, I have the ability to set this driver to simulation or hardware mode, which is perfect for my application.
    My issue is, that I run this function from a VSTA c# module via RtFunction.Start() function, which has no "finished" or "done" callback, or return value, therefore, there is no way to determine if the function has finished properly. Furthermore, I'm unable to find a way, to somehow get the status data from the driver.
    So my question is, is it possible to somehow get/read the driver status from anywhere in the system, so I can feedback that information to my VSTA module, so it knows whether the driver is in simulation or hardware mode?
    I'm using Version 7.60 SP0 Build56718 64Bit with .NET framework 3.5 SP1
    Thanks in advance!
    10.12.2007
    257
    Default AW: Get IEC870 driver state
    Have a look at Variables -> Driver Object Types -> Communication Details (or Driver Variable). A BOOL Variable at Offset 5 shows TRUE if the driver is in Simulation Mode (FALSE if in hardware mode)
    10.12.2015
    2
    Default Re: Get IEC870 driver state
    That is exactly what I was looking for. Thank you very much!
  1. IEC870 driver, use originator in REMA
    By baresi in forum zenon Energy Edition
    Last Post: 3rd December 2020, 15:27
  2. IEC61850 Driver - Connection State
    By andrea.ornago in forum zenon Service Engine Operator
    Last Post: 13th September 2017, 09:42
  3. Please help me with settings IEC870
    By focus in forum zenon Energy Edition
    Last Post: 10th January 2012, 14:27
  4. Importing variables for the IEC870 driver is hanging
    Last Post: 10th December 2007, 13:51
  5. Replies: 0
