Thread: Multi PLC Porject
    26.02.2021
    24
    Default Multi PLC Porject
    Hi everyone,
    I'm starting a new project and I have a question about drivers. My project has up to 12 machines with their own PLC each of them, what is a better option, a single driver with different net conections for each PLC or a driver for each PLC? I need to have good communication and I have to make sure the project has good scalability properties.
    Any hint will be more than welcome, thank you all.
    986
    Default Re: Multi PLC Porject
    You are not the first person asking this on the Forum, have you tried the Search ...?
    By only 12 PLCs it probably doesn't mater; eventually only if you have thousands of variables per PLC, then optimum is by 4x3 or 3x4.
    I personally prefer projects where i have an instance per PLC, then i can stop/simulate the particular driver independently. The limit are about 250 drivers (or about 80 if zenon Runtime runs as service).
    26.02.2021
    24
    Thank you, that's very helpful.
  1. sub program multi output value
    By mos89 in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 12th June 2018, 16:31
  2. Multi monitor project
    By chia.lailypour@gmail.com in forum zenon Service Engine Supervisor
    Last Post: 24th February 2018, 08:31
  3. Multi Monitor
    By andrea.ornago in forum zenon Service Engine Operator
    Last Post: 12th September 2017, 09:28
  4. Multi-Monitor with different resolutions
    By martijnvanspijk in forum zenon Service Engine Supervisor
    Last Post: 22nd May 2013, 12:26
  5. Multi-log on various projects
    By nblanquart in forum zenon Service Engine Supervisor
    Last Post: 6th May 2010, 08:24
