Thread: Screens manipulation
    01.02.2021
    Default Screens manipulation
    Hello everyone,
    I am new with Zenon, so I have a question about the screen switch function.
    I want to have one main screen (screen 1 on the picture I added) on which I want to have screen switch buttons that will open two screens (process screen 2 with different parameters replacing indices, and different dashboard screen 3). On the dashboard, I want to have a few buttons which will change parameters on the screen 2 replacing indices too. The problem occurs because the dashboard must have different number of buttons depending on what is selected on screen 1 (otherwise I would have built dashboard it into screen 2).
    Is it possible and how?
    995
    Default Re: Screens manipulation
    depending on what is selected on screen 1 you can set some internal variables and the buttons on screen 2 configure to be visible or invisible depending on those internal variables.
    additional hint: consider to use a faceplate for screen2 & screen 3.
  1. Import Screens
    By Olesia in forum zenon Service Engine Supervisor
    Last Post: 18th December 2017, 22:04
  2. Issues in Screens when converting from 6.21 to 7.2
    By salmanhassan2 in forum zenon Service Engine Supervisor
    Last Post: 3rd September 2015, 08:34
  3. Display in 2 screens
    By tuanda88 in forum zenon Service Engine Supervisor
    Last Post: 30th January 2015, 09:33
  4. Manipulation 'Screen switch'-Rt-Function via C#
    By michael.winter in forum VSTA
    Last Post: 19th November 2014, 14:46
  5. How to get Object in Screens
    By jorgedatcom in forum VBA
    Last Post: 9th January 2012, 00:32
