Thread: Web Engine Deployment Tool Error
    14.09.2017
    33
    Default Web Engine Deployment Tool Error
    While starting Web Engine Deployment tool get application error for reference please find attached image. Will you please tell me the probable reasons of it. Settings for IIS has been done as mentioned in Help file.
    Rahul.
    65
    Default Re: Web Engine Deployment Tool Error
    Quote Originally Posted by rahulindore05 View Post
    Rahul.
    Hi Rahul,
    have you installed the same version of the web server?
    14.09.2017
    33
    Zenon Web server is install of zenon 8. Earlier I had tested with zenon 8.20 version, now tried same with zenon 8 where found similar issue.
    Rahul.
    65
    Have you tried a build-upgrade or reinstall of zenon?
    It seems like files for service grid are missing - has there been a service Grid installation on this system?
    14.09.2017
    33
    There is no service grid install in system. Is it require? as per help manual we can use zenon runtime connector instead of service grid.
    Rahul.
    65
    Rahul.
    Ther is no need to install service grid. But the error states it is looking for a .dll of service grid.
    To me it seems a more recent version of zenon was installed and removed, and now the deployment tool can no longer find the requried dlls.
    Therefore i suggested a reinstall or build update
  1. Reg - Unable to run startup tool
    By saravanan1985 in forum Engineering Studio & Service Engine
    Last Post: 10th March 2020, 16:30
  2. Reg - Unable to run startup tool
    By saravanan1985 in forum zenon Energy Edition
  3. Licensing tool failure
    By negin in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 1st September 2019, 06:45
  4. Testconnection Tool
    By stefan_m in forum Diagnosis Tools
    Last Post: 2nd April 2012, 23:27
  5. Deployment of ZenOn Application
    By gralex in forum Engineering Studio & Service Engine
    Last Post: 25th July 2011, 13:02
