Thread: Function on variable change....
    30.07.2014
    23
    Frage Function on variable change....
    Is there a way to call a function when a variable value changes, i don't care what the new value is, just that it isn't the same as it was previously.   I always what to call the same function, and the variable value might for example go from 0->1->2->5->1
    Is a numeric RM the best way to do this with all the values possible and just have them calling the same function or is there a way to just say "if variable value has changed call function"?
    Editor Operator 8.2
    RT Operator 8.1
    so no VBSTA etc, just standard functions/scripts.
    thanks
    David
    986
    Default Re: Function on variable change....
    in multi-numeric reaction matrix, create one entry where: 'Value' = "Any", activate the checkbox 'treat each change of value as new limit violation'  and link the wished function as 'Instant'.
    30.07.2014
    23
    Its replies like that which make this forum what it is...
    thanks, have a good day.
  1. Change execute function pressing left click
    By carlos_sica in forum VBA
    Last Post: 25th October 2016, 11:31
  2. Function parameters - dynamic change
    By vlad_a_m2005 in forum zenon Service Engine Supervisor
    Last Post: 12th August 2016, 12:02
  3. Variable Change Event
    By parthbdesai in forum VSTA
    Last Post: 23rd February 2016, 10:46
  4. Replies: 3
    Last Post: 23rd October 2013, 22:21
