Thread: Exchange driver 3s_ARTI with 3s_V3?
    01.02.2016
    29
    Default Exchange driver 3s_ARTI with 3s_V3?
    Hi all,
    I would like to know which is the easiest way to convert existing variables for 3s_Arti_NG driver which use Symbolic name to 3S_V3 driver which use Symbolic address.
    My 1st thinking goes to editor Add-in which will
    1. goes throught all variables for 3S_Arti driver
    2. find variable 3s_Arti than exchange it to 3s_V3 and
    3. copy Symbolic name to Symbolic address field with some prefix used in codesys v3
    4. repeat for next variable...
    Is that possible?
    How to check in add-in wizard if varibale defined for specific driver?
    How to exchange driver in add-in wizard and copy symbolic name to symbolic address?
    2nd thinking, was about exporting variables in .csv file also via add-in function...
    And then 2nd add-in function which will open csv file and populate Symbolic address (3S_V3) with Symbolic name(3s_Arti_NG)...
    Thanks in advance,
    MK
    25
    Cool Re: Exchange driver 3s_ARTI with 3s_V3?
    Hello milosh,
    Is that possible?
    this is definitely possible in Add-In Framework.
    You can check this in the DynProperties of the variable. Regarding to the embedded help, this DynProperty of the variable can be addressed by the string "Driver".
    Double check with XML export if you want to be sure.
    Same. Use DynProperties.
    2nd thinking[...]
    yes, this is also possible. rather the csv use the xml export. change the properties in the XML and then import the changed xml.
    good luck!
  1. 3S_V3 driver to communicate to ABB500 PLC
    By milosh in forum zenon Service Engine Operator
    Last Post: 29th October 2019, 19:02
  2. ABB 3S_V3 Connection Problem
    By eden212 in forum zenon Service Engine Operator
    Last Post: 1st February 2018, 09:25
  3. Fanuc Robot data exchange protocol
    By baruzlor in forum zenon Service Engine Supervisor
    Last Post: 12th February 2013, 12:42
