Thread: Report Synchronizing for 2 servers
    16.07.2020
    10
    Default Report Synchronizing for 2 servers
    I have 2 Zenon copadata in 2 servers in reports, alarms, events and trends are there.
    All the data of 2 servers to be synchronized. If Server 1 is off and server 2 is ON. After some time server 1 is ON then whole data of alarms, events, trends and reports to be synchronized from server 2. similarly vice versa.
    In my scenario Alarms, Events and Trends are synchronizing. But Reports are not synchronizing.
    Can anyone help me out.
    Thanks in advance.
    Regards
    Juned
    270
    Default AW: Report Synchronizing for 2 servers
    What kind of reports do you have? Usually a report doesn't contain actual data, it is only some kind of template that defines the layout for the data.
    The real data mostly comes from Archives or online Variable values. So there is no need to synchronize the reports, only the data must be synchronized. As you say alarm and events AND TREND is working, I assume the synchronization (especially of Archives) seems to work properly.
    Are you saving the report in the runtime? Saving of reports destroys the report because it replaces the formulas in the report by the values.
    16.07.2020
    10
    Default Re: Report Synchronizing for 2 servers
    I'm using a function of Report Viewer: export/print as shown below.
    I have created a report template with few data.
    Report is saving only in primary server not in standby server.
    In the properties of this function I can see the primary server is selected and standby server is not selected and it is greyed out.
    How can I generate the reports in both primary and standby servers.
    Thanks in advance.
    270
    I did a short Test (zenon 7.60, Win10, Project defined with server and standby, only Standby Server started, Execute function to export/print report) and it worked perfectly on the standby - while he is the primary server.
    I'm not sure if I get you right, do want to print the report on both servers even when the connection is established?
    If so, you can't do that the way you want. This type of function seems to be limited to only execute on (actual!) primary server. I would suggest to use a shared network devie like a NAS as export path on both servers. Or you could use a copy function to transfer the pdf after printing.
    16.07.2020
    10
    Thanks for your Support and response.
    Yes I need to have reports in both Primary and Standby server.
    Can you share an example of copy function.
    I have tried but i can able to copy only 1 pdf. How can I copy complete folder or how can I copy latest pdf.
    As if now I'm saving the reports pdf with date and time. So all the reports will have different name.
    Thanks in Advance.
    Regards
    Juned
    270
    You can use wildcards in the Source-/Destinationpath of the fileoperation function, like "\*.pdf".
    With the options "only execute when file(s) - are younger than..." and unchecked "overwrite existing file" option you should be able to get what you want.
    Remember, you will need the same configuration of network drives on both servers (for example: mapping drive X:\ to the export folder of the other server)
    16.07.2020
    10
    Daumen hoch Re: Report Synchronizing for 2 servers
    SOLVED.
    THANKS ALOT APPRECIATE FOR YOUR PROMPT RESONSE.
    THANK YOU VERRY MUCH.
    Regards
    Juned
  1. Replies: 1
    Last Post: 28th August 2018, 08:45
  2. Zenon Redundancy in Servers & Client PC
    By avinash.malli in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 2nd July 2018, 09:57
  3. Redundant Servers - SQL Evacuation
    By adrian.mcgranaghan in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 24th April 2015, 19:16
  4. set up servers for redundancy
    By hajjsaid99 in forum zenon Network
    Last Post: 13th March 2015, 12:20
  5. Straton in multi servers system
    By altera in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 28th May 2013, 08:28
