Thread: Change RtFunctions parameters in VBA
    27.08.2008
    50
    Default Change RtFunctions parameters in VBA
    Hello!
    I want to get rid of the "Linked variable not found:" messages without erasing the functions.
    It is not possible to change the ParamString because it's "Read only" so i tried to set the type to a beep sound, which seemed to work, but there was no change in the Editor.
    Code:
    Dim iX As Integer
    For iX = 0 To thisProject.RtFunctions.Count - 1
    If thisProject.RtFunctions.Item(iX).ParamString = "xxx" And thisProject.RtFunctions.Item(iX).Type = "13" Then
        'thisProject.RtFunctions.Item(iX).ParamString = "Internal.Dummy.....off->"
        thisProject.RtFunctions.Item(iX).Type = "74"
    End If
    Next iX
    My VB knowledge is not very good, sorry for that.
    Thank you!
    27.08.2008
    50
    Default Re: Change RtFunctions parameters in VBA
    Solution found.
    Module:
    Code:
    Public Function setFunctionParameter(ByRef obFunc As RtFunction, sVar As variable, sParameter As Integer) As Boolean
    setFunctionParameter = True
        With obFunc
            .DynProperties("SetValue.Variable") = sVar
            .DynProperties("SetValue.NumValue") = sParameter
            .DynProperties("SetValue.IsDirect") = True
        End With
        Exit Function
    End Function
    Code:
    Private Sub CommandButton74_Click()
    Dim iX As Integer
    Dim obFunc As RtFunction
    Dim obVar As variable
        Set obFunc = thisProject.RtFunctions.Item(iX)
        Set obVar = thisProject.Variables.Item("Internal.Dummy")
        imFunc.setFunctionParameter obFunc, obVar, 1
    End If
    Next iX
  1. Start Program error with parameters
    By maurodx in forum zenon Supervisor
    Last Post: 16th November 2009, 06:51
  2. Change the Ip Address in Zenon 5.5
    By sikenga in forum zenon Network
    Last Post: 9th June 2009, 13:09
  3. Parameters in Property window greyed out?
    Last Post: 25th September 2008, 14:24
  4. Replies: 0
    Last Post: 21st August 2007, 08:15
