Thread: Restart Runtime
    Default Restart Runtime
    hello everyone
    i have a problem with runtime zenon
    After the project is executed, if you disconnect the monitor and reconnect that, The runtime page crashes (The full project page does not run), and unless runtime closes and reopens, it's still there.
    this problem is In all versions there.(I use zenon version 7.2)
    is there a function in zenon for Restarting Runtime ? (Online Project Reload Does not work) or Macro for closing and reopening the runtime ?
    945
    Default Re: Restart Runtime
    Does the runtime application crash (= ends unexpected)? or just the main screen (the biggest frame) is closed/hidden?
    If it is just closed frame/screen - maybe try: call the function closing the main frame, then opening the screen configured in the project to be the 'start' screen and/or the function executing the AUTOSTART script.
    as it is nothing specific for Energy, i'm moving this thread.
    hi ursulak
    I tested this function closing frame but got no answer.
    in my project , i have 2 monitors for each HMI(Like the attached photo). Apparently Zenon only checks the status of monitors, when running(When running runtime) and If there is a problem connecting the monitors after running(In runtime mode), it will no longer check it.
    The only solution to this problem, is to close the project and rerun it ,This access is only possible for the system engineer.
    I tried to write a script(similar Reset_wincc.vbs in wincc Siemens) to close and recall the runtime but Zenon requires admin access to close and is a complex task.
    In the attached photo, the Right monitor displays the project image(extended page/Continued page) Incomplete after disconnecting and connecting monitor cable. and Everything is correct on the left monitor.
    Please provide a suitable solution to this problem.
    Sincerely thank you for your tips.
    20.11.2017
    4
    bonjour
    si vous détectez la résolution avec vba via une variable Blink (1s) envoyer dans un container ?
    Declare Function GetSystemMetrics32 Lib "User32" _
        Alias "GetSystemMetrics" (ByVal nIndex As Long) As Long
    Public Function ResolutionEcranLargeur()
        On Error GoTo FunctionErreur
        Dim LargeurEcran As Long
            LargeurEcran = GetSystemMetrics32(0) 'largeur de l'écran en pixels
            ResolutionEcranLargeur = LargeurEcran
        Exit Function
    FunctionErreur:
        ResolutionEcranHauteur = ""
    End Function
    Daumen hoch Re: Restart Runtime
    Quote Originally Posted by henneuse_alain View Post
    bonjour
    Exit Function
    FunctionErreur:
    End Function
    Thanks for your solution henneuse_alain
    If possible, give the macro for 64-bit ,Because I get the following error message when running the macro
    And if possible, give more tips about this macros...
  1. Type of changes that require a restart of the runtime
    By razvan_ash in forum zenon Energy Edition
    Last Post: 6th April 2018, 12:44
  2. Restart driver
    By brc in forum VBA
    Last Post: 12th April 2013, 07:43
  3. Zenon Driver reconnect/restart
    By kicker in forum Drivers
    Last Post: 28th July 2009, 23:06
  4. Replies: 1
  5. the runtime crashes every time during the runtime start
