Thread: Periodic Synchronization of PLC
    27.08.2020
    Default Periodic Synchronization of PLC
    Hi all,
    I'm a beginner on zenon and I would like to send periodically a command of synchronization on driver IEC104 to one or more PLCs (RTUs).
    This command should be sent eg. every five minutes once the link IEC104 with the PLC is up.
    Many thanks in advance for your suggestions.
    Filippo
    955
    Default Re: Periodic Synchronization of PLC
    Create T103 variable(s) and zenon function 'write set value' to this variable. In the function activate the option 'directly to the Hardware'. Then link the function in the module Time Control.
    14.09.2017
    29
    If I Execute T103_Set function for 5 minute interval using time control, does it will affect the any other functionalities in program?
    Example: If I am providing any other Manual command and at same time periodically T103_Set function gets ON whether it affect to the command which I am providing manually?
    Rahul.
    955
    Are the modern computers performant enough to do some simple task each 5 minutes
    zenon has a function queue (help: Manual > Functions and scripts > Functions > Execution sequence during Runtime). Each function - the user/project executes - is taken into the queue and then performed. Thus, theoretically it may happen that you configure period of 5 minutes, but it will be executed after 5 minutes and 100 milliseconds instead, e.g. while RT had more as this one function. Anyway, in the ASDU<103> the driver sends the time information of command execution IN DRIVER, nothing what user did, or not did, in the Runtime before.
    14.09.2017
    29
    Thanks for your feedback.
  1. Day counter for periodic maintenance
    By doublem in forum zenon Service Engine Supervisor
    Last Post: 17th March 2020, 09:24
  2. Subproject StandBy server synchronization
    By jurijcadez in forum zenon Network
    Last Post: 20th June 2013, 02:02
  3. Time synchronization in reverse direction
    By michael_k in forum zenon Energy Edition
    Last Post: 16th February 2011, 10:33
  4. IEC-870 time synchronization
    By okhotnikov in forum zenon Energy Edition
    Last Post: 27th August 2010, 13:53
  5. IEC-870 time synchronization
    By okhotnikov in forum Drivers
