Thread: WebServer-Client Configuration
    11.02.2019
    23
    Default WebServer-Client Configuration
    Hi All,
    If I'm using Zenon Web Server Pro light, and the workstation is connected to a server gateway and using its backbone network.
    Webserver and Runtime are running at workstation.
    I would like to use webclient in another pc which is different vlan with the workstation.
    1. What PC name should I choose under network active pc option? my workstation or the server pc?
    2. Webclient error with file cannot be accessed or open graphic with blue dot but all settings as mentioned in manual has been checked and correct. Would it be different vlan issue?
    Anyone encountered these issue before?
    03.11.2015
    64
    Default Re: WebServer-Client Configuration
    Quote Originally Posted by shaun View Post
    Hi All,
    Hello Shaun,
    The Network setting in the Project must be the PC where your Runtime and Web Server is active.
    For the global_vars configuration you must also choose this PC name as your Runtime PC. For the Web Server part i would suggest to use the IP adress if you do not have name-resolution for your web clients PC.
  1. OPC DA Server- Client Configuration
    By rajeeshk1985 in forum Drivers
    Last Post: 10th January 2019, 10:31
  2. Number of Active Client @ Webserver
    By schirgitom in forum VSTA
    Last Post: 16th February 2015, 10:19
  3. Has WebServer in Demo mode WebServer or WebServer Pro functionality?
    By stolyarov_as in forum Webserver/Webclient
    Last Post: 2nd April 2014, 13:54
  4. WebServer - Client Connection
    By abcd1234 in forum Webserver/Webclient
    Last Post: 13th January 2014, 19:35
  5. OPC Client configuration
    By luca.bardon in forum Drivers
    Last Post: 17th October 2012, 10:08
