Thread: Killing webclient from runtime
    26.01.2010
    6
    Default Killing webclient from runtime
    Hi there...
    Is there a function where i can shutdown the webclient (explore) from the client???
    I have 5 webclient and only 1 web licens that they have to share...
    So i would like to have a button in the runtime the user just cut press, and then it would shutdown the explore. And make the licens availeble for other webusers...
    879
    Default Re: Killing webclient from runtime
    take a look at this thread http://www.copadata.com/forums/showthread.php?t=154
    26.01.2010
    6
    Hi Herbert...
    I just try the code from the link above, but it did not work.
    When i open the VBA editor, and try to compile it (F5) i get this error message.
    "Compile error
    Constants, fixed-length strings, arrays, user defined types and Decalred statements not allowed as Public members of object modules"
    Regards
    Michael
    879
    Hello Michael,
    "Public Declare ..." work in modules.... (this is realted to VB restrictions)
    You have 2 options:
    - create an new VBA Module and copy & paste the mentioned code
    - write "Private Declare ... " when using it in thisProject
    26.01.2010
    6
    Hi Herbert...
    Now i get the MsgBox on the client, but insted of closing the explore, it crash. And i have to kill it from the taskmanager...
    Im using XP embedded with explore 7.0.5730.11
    Regards
    Michael
    26.01.2010
    6
    Hi Herbert...
    I fixed it by sending a ALT+F4 key to the program...
    Thanks for your help :-)
    Regards
    Michael
  1. WebClient Screen Configurator
    By herberto in forum zenon Network
    Last Post: 23rd March 2016, 13:17
  2. Which OS for the zenon webclient?
    By markclemens in forum Webserver/Webclient
    Last Post: 20th March 2010, 18:29
  3. Remove double scrollbar in Zenon WebClient
    Last Post: 1st October 2009, 15:11
  4. Replies: 1
  5. VBA on webclient
    By markclemens in forum VBA
    Last Post: 14th September 2007, 08:01
