Thread: CanOpen Pdo mapping Via Straton
    28.11.2017
    19
    Default CanOpen Pdo mapping Via Straton
    Hi is there a simple way to set the pdo mapping of some slave via straton
    02.12.2021
    Default Re: CanOpen Pdo mapping Via Straton
    Hi, The systems the entire process image is continuously transferred - usually in a more or less cyclic manner. CANopen is not limited to this communication principle, since the multi-master bus access protocol allows CAN to offer other methods. In this model, a bus node transmits its data, as a producer, on its own accord. This might, for example, be triggered by an event. All the other nodes listen, and use the identifier to decide whether they are interested in this telegram, and handle it accordingly.
  1. elmo drive canOpen mapping reseted
    By mos89 in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 21st February 2019, 17:11
  2. canOpen coWriteParam function block
    Last Post: 7th June 2018, 11:39
  3. OPC - Quality bits mapping
    By arn in forum Drivers
    Last Post: 24th January 2018, 10:44
  4. Mapping mit Variablen
    By sebiko in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 26th November 2014, 08:15
  5. mapping a Networkdrive on a CE device
    By martinw in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 19th September 2007, 07:58
