Thread: Cant start 6.22 after installation of 6.51 (removed everything, reinstalled)
    10.12.2010
    55
    Default Cant start 6.22 after installation of 6.51 (removed everything, reinstalled)
    Hello
    I have been running zenon 6.22 on my win 7 32bit for some time without any problems. After I have installed 6.51 I can no longer start 6.22. When I try it starts to configure 6.22, but I get the error:
    Error 27502. Could not connect to Microsoft SQL server ".[DBNETLIB[ConnectionOpen(Connect()).]SQL server does not exist or access denied (17)
    I have tried to uninstall 6.51, 6.22 and the sql server, deleted programdata/copa-data/*.*, and c:\program files\copa-data\. Then I reinstalled 6.22, but after installation, I can still not start the editor. It gives the same error.
    I looked into the startup tool(http://www.copadata.com/forums/showthread.php?t=932). There is no entries.
    I ran the TestConnection tool (http://www.copadata.com/forums/showthread.php?t=785) and attached the output.
    If I select Check Connection->6.22 it checks entries to, and including, "c:\programdata\copa-data\system\zenDB.ini" and a popup shows: "ODBC Actions Plugin", "Action not available in evaluation build". If I press OK it continues and everything seems to be ok.
    Screenshots and connectiontest export is included in the zip in the folder "Screenshots and exports"
    Attached Files Attached Files
    10.12.2010
    55
    Default Re: Cant start 6.22 after installation of 6.51 (removed everything, reinstalled)
    Oh... and I uninstalled everything similar to : MSXML parser
  1. Replies: 0
    Last Post: 18th August 2010, 14:52
  2. parallel installation of two servicepacks
    By markclemens in forum Editor and Runtime Setup
    Last Post: 24th February 2009, 09:00
  3. Silent installation of Zenon
    By cleitgeb in forum Editor and Runtime Setup
    Last Post: 1st December 2008, 15:26
  4. Installation on Touch Screen using DOM
    By tauhien in forum Editor and Runtime Setup
    Last Post: 26th September 2008, 02:56
  5. Please Guide me about New Installation??
    By majidhanif in forum zenon Operator
    Last Post: 19th November 2007, 13:00
