Thread: S7TCP Driver IP Address
    10.03.2011
    Lächeln S7TCP Driver IP Address
    Is there a Driver Variable or other means to display the Driver's (Primary) IP Address?
    Thank you
    08.10.2007
    35
    Default Re: S7TCP Driver IP Address
    there is no driver variable which offers the IP Address.
    But some driver have a configuration textfile where the setting is stored, there it could be taken from.
    Depending on the driver you use, check if there is a textfile added to the zenon project. This file can be found in a zenon project under Files -> driver and is also in the runtime available. The S7TCP driver creates such a textfile as far as I know!
    20.07.2017
    Rotes Gesicht Re: S7TCP Driver IP Address
    Hi
    I want to connection logo PLC to zenon, Can I ? I could connection between S7-300 and zenon, but about Logo I don't know,,
    Could you help me?
  1. IP-address variable
    By croc in forum Drivers
    Last Post: 31st January 2012, 09:51
  2. S7TCP/IP Uhrzeit setzen
    By herrmoartl in forum Drivers
    Last Post: 11th October 2011, 11:13
  3. Simulation IEC 104 address
    By kirca in forum zenon Energy Edition
    Last Post: 1st September 2011, 23:26
  4. Change the Ip Address in Zenon 5.5
    By sikenga in forum zenon Network
    Last Post: 9th June 2009, 13:09
    Last Post: 21st August 2007, 09:23
