Thread: WebClient Screen Configurator
    879
    Idee WebClient Screen Configurator
    When starting the WebClient and thus also the Internet Explorer the WebClient will be started only at the first screen per default.
    In the attachment of this post you can find a small application which starts the WebClient (Internet Explorer) at the given position (Left/Top) together with the given window size.
    Optionally the Internet Explorer can be started in fullscreen mode (without Title bar, menu bar, address bar, ... )
    Starting the application with the command line parameter /h will start the WebClient directly (so without showing the configuration dialog):
    ie. "C:\WebClient_IE_MultipleScreens.exe /h"
    All settings are stored in following file:
    %temp%\zenWebCli\WebClient_MultiMonitor.ini
    Note: Do not forget to specify a sperate Monitor-Profile in then zenon.ini:
    [DEFAULT]
    SCREENPROFILE=MYWEBCLIENTPROFILE
    If you have any comments/requests/... regarding this applicaton do not hesitate....
    Note: this application is not an official tool from CopaData
    Regards and hf,
    879
    Default AW: WebClient Screen Configurator
    Due to a customer request a updated version of this tool can be found in the attachment.
    Changed:
    at the URL-parameter it is now also possible to define i.e. \\PC1.htm
    -> this is a URL for opening a file from a destination PC (WebServer)
    Before the given URL was checked if there is was "http://" inside
    879
    Default Re: WebClient Screen Configurator
    Please find attached a revised version of this tool
    ChangeLog:
    - fixed issue with starting application with the /h parameter
    - GUI rework (design/usablity/typo)
    - URL validation enhanced (entered URL must be reachable now)
    11.04.2016 (replaced attachment)
    - URL validation now allows local htm files also (old way for starting Web Clients without IIS)
    14.09.2016 (replaced attachment)
    - blanks within the URL are now possible again (leading/trailing blanks are still removed)
    regards,
    herbert
  1. Which OS for the zenon webclient?
    By markclemens in forum Webserver/Webclient
    Last Post: 20th March 2010, 18:29
  2. Remove double scrollbar in Zenon WebClient
    Last Post: 1st October 2009, 15:11
  3. Screen resolution
    Last Post: 16th May 2008, 15:49
  4. screen template
    Last Post: 24th April 2008, 08:00
  5. VBA on webclient
    By markclemens in forum VBA
    Last Post: 14th September 2007, 08:01
