Thread: Zoom Respone Image
    20.07.2020
    6
    Default Zoom Respone Image
    Hi, again
    What is the easiest and fastest way to show a symbol, but at a certain screen zoom level, change the symbol?
    I had thought about using the combined element, but I don't know how to set a variable related to screen zoom
    Many thanks in advance
    ER
    10.12.2007
    238
    Default AW: Zoom Respone Image
    Hi again
    have a look at worldview/overview help in the manual. You have to define ZoomSteps in the project properties (section grafics). Afterwards you can select for each an every element in a screen when it should be visible in the runtime (select element -> properties window -> Runtime -> Overview -> Visibility From/To)
    It is a little bit tricky to configure it so it fits your requests. I recommend you to do a little bit of testing until you understand how it works and find the best settings.
    You can do a lot of nice things with this "decluttering". For example you can create/define symbols that show more and more information the further you zoom in.
    20.07.2020
    6
    Daumen hoch Re: Zoom Respone Image
    Oh perfect! I thought that by using the worldview function, I was forced to implement zooming of screens with this function as well.
    Anyway I solved it, thanks a lot again.
  1. insert image in a synbol or in a screen
    By andrea.ornago in forum zenon Operator
    Last Post: 11th July 2017, 07:09
  2. Button Graphics Image
    By conradsmith in forum VBA
    Last Post: 14th January 2013, 23:37
  3. Camera image in browser window
    By gandi in forum zenon Supervisor
    Last Post: 14th January 2013, 08:40
  4. Zoom Objektliste
    By massinger in forum VBA
    Last Post: 10th December 2010, 00:19
  5. 0% Zoom required
    Last Post: 20th July 2010, 08:49
