Showing results 1 to 1 of 1
Thread: Test station for a pair of protocols
    06.07.2020
    Default Test station for a pair of protocols
    Hello all,
    I have a fee questions, and I hope someone can shed some light!
    I am using SICAM230, a scada software based on zenon copadata.
    I amusing this software to read the values from several devices that speak protocols 104 and 61850.
    I want to create a testing environment for said protocols. I got thw idea that it might be able to set up a PLC, have it speak the aforementioned protocols (obviously one at a time), meaning set it up as a slave device, so that I can see its values on the SCADA program.
    Is this at all possible to do with a PLC? I can buy any Siemens PLC.
    I looked into the S7-1200,which has an additional module for iec 104 bit it would seem not for 61850,and the S7-300,which seems to support both natively.
    Is it possible to do this with these PLCs for the respective protocols?
    jiofi.local.html
    192.168.8.1
    router network
  1. Replies: 1
    Last Post: 1st April 2020, 14:43
  2. Zenon operator station
    By sandeep2018 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 26th July 2019, 10:02
  3. Replies: 1
    Last Post: 11th March 2019, 09:00
