Page 3 of 3 FirstFirst 1 2 3
Showing results 21 to 25 of 25
Thread: Buffer/Unbuffer report
  1. #21
    Default Re: Buffer/Unbuffer report
    Hi
    The time that GE report is later 7 hour than the point happened. But the time in event record of relay is right time.
    I use zenon 6.50 SP0.
    Thanks.
  2. #22
    if it is a "round" number, like exactly 7 hours off, you may want to check any possible time zone settings in your hardware.
    zenon internally logs times in UTC, but displays the times according to the timezone of the PC that the runtime is running on.
  3. #23
    Hi
    My computer set time zone GMT+7 so it seem that after received message , time display in alarm, cel plus 7 hour.
    But I can not done like this (set back to GMT for computer or minus 7 hour for GE) because of I have another device REGDA that display right time-stamp in both zenon and local.
    Could you give me a suggestion?
  4. #24
    I don't know the GE hardware, but I could imagine that it is possible to define a time zone somewhere in the configuration for the GE device.
  5. #25
    Hi Markclemens
    Thanks for your repply.
    I have some mistake that I seen the time record in relay same as computer but the relay already has setting call " LOCAL TIME OFFSET FROM UTC",,,. the offset is used to calculate UTC time for IEC61850 features.
    Thanks a lot
    Brdgs.
  1. Report
    By hoscillada in forum zenon Supervisor
    Last Post: 30th November 2009, 00:20
  2. Seitenumbruch im Report
    By sscherfling in forum zenon Supervisor
    Last Post: 25th November 2009, 09:58
  3. Report Generator
    By rolindo in forum zenon Supervisor
    Last Post: 21st November 2009, 23:50
  4. Report Help
    By ziadrached in forum zenon Supervisor
    Last Post: 26th November 2008, 09:08
  5. Report zeigt nichts an
    By sknoerr in forum zenon Supervisor
    Last Post: 28th August 2008, 11:32
