Thread: Import Alarm XML
    03.02.2020
    2
    Default Import Alarm XML
    Is there a way to import Alarm from XML with the API?
    Thank you.
    03.11.2015
    34
    Default Re: Import Alarm XML
    In fact, there is currently no possibility to trigger an XML import on Alarm-Areas, -Groups, or -Classes with the AddIn-Framework (zenon API).
    It is however possible to create Alarm-Areas with DynProperties of the project.
    So technically, ther could be a possibility to parse the XML file and create the the alarm classes in an Editor Wizard Extention.
    Here is a simple example on how to create an alarm class in an Editor Wizard Extention:
    public void Run(IEditorApplication context, IBehavior behavior)
          var activeProject = context.Workspace.ActiveProject;
          var dynProps = activeProject.GetDynamicProperties("");  // this is to get all DynProperties of the project. You can watch them in the watch or locals window.
          activeProject.CreateDynamicProperty("AlarmClasses");
          var alarmClasses = activeProject.GetDynamicProperty("AlarmClasses"); // Returns the number of Alarm Classes in the project.
  1. Double Click Acknowledge of alarm on Alarm Screen..!
    By daujivar in forum zenon Service Engine Supervisor
    Last Post: 31st August 2016, 07:22
  2. Problems with alarm list and alarm time
    By dario in forum zenon Service Engine Supervisor
  3. Alarm Status Line and Alarm List
    By tomaslipa in forum zenon Service Engine Supervisor
  4. Replies: 0
