Thread: Extended Trend - Disable dragging / moving of Scale
    26.11.2010
    28
    Default Extended Trend - Disable dragging / moving of Scale
    is was not able to find an option to lock the position of Y- and X-scale in a diagram of type extended trend.
    We want to prevent the user from moving the scale of X and Y axis by mouse/touch control. How can this be achieved?
    Thanks.
    BR
    Eric
    Default Re: Extended Trend - Disable dragging / moving of Scale
    A solution can be to disable completly the control at Rutime (naturally by coding):
    Code:
    [AddInExtension("Disable ETM", "Your Project Wizard Extension Description")]
        public class DisableTrend : IProjectWizardExtension
            [DllImport("user32.dll")]
            static extern bool EnableWindow(IntPtr hWnd, bool enable);
            public void Run(IProject context, IBehavior behavior)
                if(context!=null)
                    try
                        Scada.AddIn.Contracts.ScreenElement.IScreenElement myElement = context.ScreenCollection["ETM_Screen"].ScreenElementCollection["ETM_Object"];
                        if(myElement!=null)
                            EnableWindow((IntPtr)myElement.WindowHandle, false);
                    catch (Exception ex)
    26.11.2010
    28
    That works, but reneders the cursor also locked.
    Thanks anyway.
    BR
    Eric
  1. [Extended Trend] Zoom in the trend with the mouse ?
    By eegabs in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 3rd April 2018, 09:47
  2. Replies: 3
    Last Post: 21st June 2017, 11:05
  3. trend element scale
    By hash84 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 17th September 2013, 15:27
  4. Disable grid lines in trend XY
    By galax in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 3rd April 2013, 09:42
  5. Extended trend with opc-variable
    By robcha in forum Drivers
    Last Post: 17th October 2012, 09:17
