Showing results 1 to 9 of 9
Thread: Function and scripts
    06.07.2020
    7
    Default Function and scripts
    I have a pop up Image with some pushbottoms, eachone writes a different number in the same  variable A; now i need more pushbottoms (to write more numbers) so i copy the pop up with all pushbottoms  changing their functions  and scripts (just the value written). The result is that all new pushbottoms write the same number in the variable A. Someone could tell me where i'm wrong, please?
    (Zenon 6.22)
    273
    Default AW: Function and scripts
    Did you configure all the functions properly and link them to the right buttons? Maybe you are always calling the same picture with the same functions.
    Click and hold the right mousbutton (=RMB) on a free space of the popup screen during RT (showing name of the picture), if the screen is ok, check the functions on your pushbuttons by click and hold RMB (showing function name). If screen and functionnames seem ok, check the values in your SetValue Functions.
    06.07.2020
    7
    Default Re: AW: Function and scripts
    Thanks mst
    To check the values in the SetValue Functions I see just this: from "Functions" i have for each pushbuttom 1 Script with 3 functions, for example pushbottom1:
     setValue--VariabileA--20
     setValue--VariabileB--ON
     close image.
    Is it this all i can Check?
    1,038
    Default Re: Function and scripts
    when you link with a button not a function but a script, then in the background, the zenon Editor automatically creates a new, additional function calling this script an links this additional function with the button. So it only looks that button is linked with a script, but in real - in both cases the button is linked with some function.
    Are your buttons then linked with different functions calling different scripts?
    06.07.2020
    7
    ursulak and all
    As you can see the attached screenshots, each pushbottoms has different parameter;
    It seems that the variable written has a limit , but i cheked and it doesn t
    I really don t know how to solve it
    For mst
    Later i'll try on RT
    Attached Thumbnails Attached Thumbnails scelta_ricetta2.bmp   scelta_ricetta2_2.bmp   scelta_ricetta2_3.bmp
    1,038
    your screenshots are from Editor set to use language I do not understand, so i'm not able to guess what settings you show. For publishing screenshots switch Editor to English.
    The relevant things are button property 'function', then this function calling script, and this script. If I right understand your use case, than by each button it should be another function calling another script.
    06.07.2020
    7
    Here switched to english
    Thanks!
    Attached Thumbnails Attached Thumbnails scelta_ricetta2.bmp   scelta_ricetta2_2.bmp   scelta_ricetta2_3.bmp   scelta_ricetta2_4.bmp   scelta_ricetta2_5.bmp
    273
    Looks like you have only Variables linked to the buttons but no functions to call the scripts. (You can use a button to directly switch a binary variable without function).
    If you want to execute a script you must not link a variable and make the button a switch
  9. #9
    06.07.2020
    7
    OK I think it is solved; i 've found the same function, for all pushbottom, launched from limit2 propriety of a variable; later i'll try on RT
  1. Function scripts can not delete
    By skywalker in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 16th February 2016, 10:05
  2. Function/ scripts can not be deleted
    Last Post: 22nd January 2016, 06:43
  3. VB scripts for WindowsCe platforms
    By martinw in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 12th June 2012, 13:21
  4. VBA scripts by alarms events
    By captain in forum VBA
    Last Post: 14th August 2008, 09:30
  5. Renaming scripts loses the link at the function
    By markclemens in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 3rd August 2007, 07:23
