Thread: Get/Set resource label with zenon logic
    04.04.2017
    5
    Default Get/Set resource label with zenon logic
    Hi!
    Is it possible to get and set the resources label (Betriebsmittelkennung) of a zenon variable with zenon logic at runtime?
    Thanks!
    Thomas
    916
    Default Re: Get/Set resource label with zenon logic
    NO.
    If I right remember you can only get (but for sure not set) the name of variable as STRING (via access to it as "symbol"). Or to be more precise - the string which is the address of the variable in straton communication protocol (binding between Runtimes, Workbench - Runtime connection, stratonNG driver).
    04.04.2017
    5
    thank you for the fast response!
    Thomas
  1. Dynamic text in Reaction Matrix using resource label
    By klimEDS in forum zenon Supervisor
    Last Post: 11th January 2020, 13:40
  2. zenon logic doesn't communicate with external variables in zenon
  3. Re: zenon logic doesn't communicate with external variables in zenon
  4. AML&CEL Resource Label Filtering
    By yavaskoray in forum VSTA
    Last Post: 14th October 2013, 23:17
  5. Display a recources label of the variable
    Last Post: 17th June 2013, 09:36
