Thread: Reading RDA Array(Real Data Type) from Beckhoff Twincat NG Driver
    01.05.2020
    2
    Default Reading RDA Array(Real Data Type) from Beckhoff Twincat NG Driver
    Our requirment is to capture live data from PLC (Real Data type) and capture it in Extended Trend. We have to capture live data for every 10 ms from the PLC. We have created RDA Array[50] inside the PLC of Real Data type and provided  the data from Index [0] to Index[6] as per the format and from Index[7] to Index[50] real time data was passed.  When we triggered the zeroth Index  data is not captured in Archive Screen (.ARX file was not created in the folder path) and we cannot view anything in extended trend. But all the RDA Array[50] variables are communicating when observed in variable Diagnostics.
    When we tried with Double Word data type, the archive is working and for every 10ms values are captured in the Archive screen and can be viewed in Extended trend Screen as well.
    Can someone clarify whether any particular setting has to be done for capturing RDA array variable for Real data type and is there any Hardware specification to be considered.
    I tested with the below provided Specifications
    • Zenon Version:7.60
    • Build Version:64404
    • Driver: BECKHNG
    • OS: Windows 8.1 Pro
    • RAM: 4GB
    • PLC: TWINCAT-XAE PLC 3.1.0.0
    Thanks in advance.
    987
    Default Re: Reading RDA Array(Real Data Type) from Beckhoff Twincat NG Driver
    Have you tried to rebuild the TPY-file and re-import the variables?
    01.05.2020
    2
    We tried that too. But it did'nt work. When trying to open archive revision screen after giving trigger, the application started to hang. What might be the cause of this error?
  1. Replies: 2
    Last Post: 12th May 2020, 16:18
  2. ENUM as base data type / Beckhoff TwinCat NG Treiber
    By RaphaelVogt in forum zenon Service Engine Operator
    Last Post: 31st January 2020, 08:48
  3. IEC61850 Driver - Data Type
    By andrea.ornago in forum zenon Service Engine Operator
    Last Post: 11th October 2017, 08:48
  4. Beckhoff TwinCat NG driver -> Red square
    By sdolnyy in forum Drivers
    Last Post: 4th March 2013, 09:49
  5. Bug report for <Beckhoff TwinCat NG driver>
    By lephis in forum Drivers
    Last Post: 6th March 2012, 10:11
