Thread: WEB Server does not start
    08.02.2018
    9
    Default WEB Server does not start
    I am using Zenon8.00.
    When project compiled for web I get warning like this : Illegal characters in path.
    Runtime and Webserver installed on same computer.
    When I try to start WebServer it is not starting, simply nothing happens.
    I updated global_vars.js file with project name and computer name, but still Web Server is not starting.
    I kindly ask your assistance to understand problem.
    Thank you
    Attached Thumbnails Attached Thumbnails compile.PNG   global_vars.PNG   webserver.PNG
  2. #
    03.11.2015
    57
    Default Re: WEB Server does not start
    It's possible to run the web server with a Demo license, unless the demo has a trial period set and has ended.
    You can verify this in the license manager.
    I would recommend to open the web server window and press "start". After starting, the web server will show "Running in Demo Mode" and show available clients, or not launching at all.
  3. #2
    03.11.2015
    57
    may I ask what you like to deploy?
    In case of a HTML5 webengine you do not need a web server. In case you'd like to deploy a regular web client you do not need to compile for web.
    Does the directory of the project or the project itself contain any special character?
    BR,
    Joris
  4. #3
    08.02.2018
    9
    Hello Joris,
    Thanks for your answer.
    I typed in red my answers.
    Quote Originally Posted by joris.l View Post
    may I ask what you like to deploy? I would like use Web Server.
    Runtime Project directory "C:\Users\Etap\Desktop\ETI"
    Project Name "CENGIZ_GES"
    BR,
    Joris
  5. #4
    03.11.2015
    57
    If you simply like to use the web server without HMTL5 solution, you do not need to compile the project for web.
    Simply create the runtime files and start the runtime, configure the Web Server with the global_vars.js config and connect to the runtime over a web client.
  6. #5
    08.02.2018
    9
    I am using Demo Licence.
    I applied your instructions, but result is same.
    I checked with Diagnosis Viewer, screenshot in the attach.
    Isn't it possible to start WebServer with Demo licence?
  7. #6
    03.11.2015
    57
  1. Zenon RT Services won't start on Standby Server
    By Pooyan_s95 in forum zenon Network
    Last Post: 20th May 2020, 12:53
  2. Web Server Pro Light - how to start, which browser I can use
    By yolovs in forum Webserver / Webclient Setup
    Last Post: 23rd October 2017, 12:48
  3. Web Server Runtime - Start and pictures
    By martin@bmw in forum Webserver/Webclient
    Last Post: 29th June 2009, 19:56
  4. Start Function From PCE
    By stephanepilon in forum VBA
    Last Post: 16th May 2008, 06:33
  5. Start a VBA Macro with PCE
    By mrk in forum VBA
    Last Post: 21st March 2008, 17:43
