Thread: Driver creation
    28.09.2015
    16
    Default Driver creation
    How to create drivers propertly?
    We have several ways:
    1 Create an driver for each machine
    2 Create single driver and configure all machines in it.
    3 Limit machines created inside diver.
     What limit it should be then?
    1,033
    Default Re: Driver creation
    Generally - do like you want. It has no significant impact.
    Only if each device delivers much data (thousands of variables and values changing frequently) and/or you have a network project where zenon network clients computers are acquiring most of the data, e.g. to transfer it via zenon Process Gateway or to some external application:
    --> then for each device create a driver instance.
    This will help the Operating System (Windows) to schedule those driver applications on different CPU cores (modern PC have many cores), and zenon Runtime can easier multi-thread the data acquisition and provide it to the Network.
    If you have a thousand devices, then the optimum is probably when the quantity of driver instances is similar the quantity of connections in an instance, e.g. 1200 devices -> 30 drivers, each with 40 connections. But also 120 drivers with 10 connections or 12 drivers with 100 connections - are almost same performant.
  1. Replies: 2
    Last Post: 19th May 2018, 06:19
  2. Button creation
    By satyngar in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 14th July 2014, 11:37
  3. Import / Automatic creation of Variables in STRATON
    By prasadkh in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 29th December 2009, 01:19
