Thread: Using the Remote Transport in the Add-In interface
    07.07.2020
    Frage Using the Remote Transport in the Add-In interface
    I noticed using the IRemoteTransport interface that the Event RemoteTransportTransferCompleted probably does not work as intended. In the project RemoteTransportTest.zip the mentioned Event is not getting triggered and the runtime does not start. While working on a work around i noticed that the runtime will start after manually closing a MessageBox (RemoteTransportTest2). I guess there are some Timing problems with transferring runtime data and starting the runtime. If you would open a MessageBox in the project RemoteTransportTest.zip after transfering the runtime files, the event triggers but does not start the runtime.(To verify that you can write some text to the output window in the zenon editor) To get the Event to work/ get the runtime started you have to stop the code temporarily (for example MessageBox). Furthermore i noticed if you go step by step through the code in RemoteTransportTest2.zip in debug mode (without displaying the messagebox) the runtime will start. My question is if i made mistakes when using the RemoteTransport Interface or if this is some kind of bug.
    Attached Files Attached Files
    07.07.2020
    Default Re: Using the Remote Transport in the Add-In interface
    Update: I reported this to the Copa-Data support and they could recreate this problem and is currently reviewed by the developement team.
  1. Bilddateien ohne Remote-Transport übertragen
    By jonaskar in forum zenon Supervisor
    Last Post: 26th February 2020, 09:11
  2. Remote transport
    By tihomir in forum zenon Network
    Last Post: 23rd June 2014, 08:00
  3. Remote transport
    By tihomir in forum zenon Energy Edition
    Last Post: 10th May 2013, 08:13
  4. Replies: 5
    Last Post: 31st March 2009, 09:27
  5. remote transport
    By stephanepilon in forum zenon Supervisor
    Last Post: 5th May 2008, 08:13
